Run subVIs in parralel and simultaneously
Hello, Using LabVIEW 8.5 in WinXP 1.6Ghz, 1GoRAM
I'm doing measurement acquisition using two agilent 66319B DC source and the driver AG663xxx. I just want to run the two measurements simultaneously from my template subVI that control the two DC Source in order to correlate the measurements. I saw mutiple discussions and can't figure it out.
Did I need to open reference to the vi and run it or simply change something in my subVis properties to handle multiple calls and runs in parralel. ??
Any help...
(2,831 Views)
When you say simultaneously, how close to you have to have the timing measurements. If you are just looking approximately the same time, you can either generate a parallel loop and do the measurements or modify the template to read the data at the same time.
(2,826 Views)
Thanks for your reply. I want that the two subVis that control the two DC source start their measurements at the same time. In the main VI I don't have a loop, I just call the template measurement VI two times and set the two adress of my apparatus to this subVis.
When I animate the execution I saw that one subVi is executed and when it finishes the second one starts.
How can the two calls of the SubVis Model can run at the same time?
(2,799 Views)
