Run time EDIT menu - how to enable/disable items properly?
--- I don't use RTM files, since I duplicate the basic items in every window, I don't want to have to change umpteen RTM files when something changes in the basics.
FYI - The same RTM file can be used for multiple windows. For example, when I have an auxiliary window for my program, I like to have the basic CRTL-W close the window. I make one RTM that has this shortcut and apply to whatever window and however many windows I want. Just make sure you include the RTM file in the build.
Cheers,
mcduff
Message 11 of 12
(630 Views)
in 25 years of  LabVIEW experience, this is my first project that uses menus extensively.  i found it easier to include the basic stuff in code and not have to switch back and forth with editing separate files.  Since I have a list of open windows in one menu, and other dynamic lists, I have to use code anyway.
In any case, that has no bearing on the issue, that I can see.
Steve Bird
Culverson.com
LinkedIn
Message 12 of 12
(621 Views)
