Run time Property settings
I want to set some of the property of the front panel controls at run time. These properties can be differents. I want to set it by name.
e.g. Test.text = "test"
OR DUT.text = "HP 8350"
OR TestResult.ColumnHeading = (1,2,3,4) etc.
Here with attaching one file which explain my current approach.
But in this it restrict my usage of Control and their properties as well.
I want to use each kind of property available for selected control programmatically. If any one have idea how I can do it using LabVIEW plz. let me know.
I am using LV 7.0
Regards Vishal
(2,843 Views)
Because properties available vary with the type of control this is not as straighforward as one might think. If you limit yourself to just a few types, and obtain references dynamically from a front panel -> controls reference list, and use the To more specific class function to get access to the right properties it can be done without that much work...to make a more general tool is demanding though.
However - if that's your ultimate goal - in the last LTR issue a property saver toolkit by Konstantin Shifershteyn is discussed, and the toolkit is available on the web, check it out at:
http://www.kshif.com/lv/index.html
(2,843 Views)
