Run-time engine of Labview 8 coexisting with Labview 7
Hello everybody!!
I have 2 questions about coexisting of different versions of Labview:
First question: We have several machines with the run-time engine of Labview 7, and where executables of this version of Labiew are running. Now, I have been developping new softwares using Labview 8, and I would like to execute them in the same machines. I guess that for these new programs I have to install the run-time engine of Labview 8. Could that affect in any way the execution of the former softwares?Because for us the proper execution of the former ones is crutial.
Second question: In other machine, Labview 7is installed. Also in this machine we would like to run a Labview 8 executable. We would like to keep there Laview 7. So, if I install there the run-time engine of Labview 8, could that affect to Labview 7?
Thank you!!
(2,712 Views)
Accepted by topic author 1000a
Simply install the LabVIEW 8 runtime. It will not conflict with older runtime engines or LabVIEW installations.
(2,707 Views)
