Run time engine
Hi everyone
I have finished my vi and also generated its Exe and testing it with another PC that whatever I want to send is received by second PC or not and for that I am using EZterminal program. And problem is when I am running my application with the PC on which I had developed it it works properly. But when I run my application on other PC it won't send anything. So where is the problem. Here i am using LabView 12.0.1 SP1. here i have attached my vi
(3,458 Views)
Have you installed the runtime engine and needed addons on the target computer?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,445 Views)
Hi...
Yes i have inatalled the labview run time engine in target PC.
(3,442 Views)
Hi..
With LVRTE is it needed other add-ons?  As here i am using VISA so is it neede to install on target PC?
(3,441 Views)
Yes, of course you need VISA. You would have seen this as an additional installer if you had actually built an installer.
(3,433 Views)
Thank you for help i haven't selected NI-VISA runtime in additional installers. What other add-ones i need to select.
(3,413 Views)
Hello Dennis
I just want to ask that if i built an installer for my application and install it in target PC then will my app.EXE will run because when i simply install my installer it opens myfront panel but sends nothing to other pc? Or i need to inatall run time engine and VISA run time saperatelly. because when i am installing my instaler in control panel it only shows national instruments software and nithing like NI labview run time engine x.x.
(3,408 Views)
