Run time error while installing Labview 8.6.1 in Vista x64
hai friends,
           i got an error( Run time error) while installing Labview 8.6 software. this software has bought from NI. it shows the error path as setup.exe. this software i had tried to install in vista x64. but when i am installing the same software in windows xp, it is installing fine...so what was the problem for this error. how to solve it, please help me....
(3,596 Views)
see this
Message Edited by muks on 02-23-2010 06:39 PM
(3,567 Views)
msarun,
Do you have Windows on Windows mode (WoW64) on your computer?  (This is required)
Are you running the installer as Administrator?
Can you provide us with some more details about the "Run-Time" error.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,550 Views)
Thank You Mr.Jason Daming,
Same error what post Mr.muks referred in the last reply....
When the installation begins an error occurs (after the acceptance of licence step in the installation procedure) with the title on the error window "Microsoft Visual C ++ Runtime Library " and displays the program set up path with these statements " This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information."
while installing the same Labview in windows XP..... it is installing fine... but in vistax64 only i am facing this kind of problem...
(3,526 Views)
