Run vi from button
I have a main VI that will call other VI's
How do I implement several user buttons that that each calls a seperate VI?
Thanks.
(3,215 Views)
this may help:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,196 Views)
in order to get to the subvi node setup you need to right click the vi and go to the subvi node setup and it will take you to the screen I have on the first jpg
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,194 Views)
