RunTime Engine and Tdms Files
I have built a application with Labview 8.2.0, NI DAQmx 8.3 and NI USI TDMS Plugin 1.0.
My appli work very good on my developpement computer, but when I install the appli on computer with RunTime Engine 8.2.0, NI DACmx 8.3 and NI USI TDMS Plugin 1.0, I have a error. If I use RunTime Engine 8.2.1, NI DACmx 8.5 and NI USI TDMS Plugin 1.0, I have a error to.
The error is 2500.
How I can use my appli with a run time ????!!
(3,851 Views)
Not sure about the first half of the problem, but the second half sounds related to this.
-Kevin P.
(3,843 Views)
Thanks Kevin,
I have install the new version of RTE 8.2.1 & NI DACmx 8.5 because my app don't work with the RTE 8.2 & NI DACmx 8.3.
I don't understand I go to reinstall RTE 8.2 & NI DACmx 8.3.
If any one have a suggestion ....
Thanks.
Rémi
(3,836 Views)
I suggest you to reinstall everything on the second machine, because what you did seemed to be the right thing to do, you must install the same run-time version as your LV version (what you did at first) and every soft or plugin you VI needs.
I really think it will work...  (I hope)
Regards
Richard Keromen
(3,805 Views)
