Running A LabVIEW executable in Windows 7
Can I run a Labview executable created with Labview 8.6(32-bit) in windows 7 or Vista. If this can be done then how to do it? I've tried copy the lvrt.dll(run-time engine) into the system 32 folder, but  it doesn't solved my problem. For info, My Labview exe file also consist the fuzzy logic toolkit.
Hope someone will help me. Thanks
Lojius
(4,487 Views)
hi lojius,
  For that you need to install labview 8.6 run time engine which is freely downloadable....Please find it at the link
http://joule.ni.com/nidu/cds/view/p/id/1101/lang/en
thanks and regards,
srikrishnaNF
Message Edited by srikrishnaNF on 03-23-2010 05:46 AM
Srikrishna
(4,483 Views)
Accepted by topic author lojius
Refer to http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/ps/30/sn/catnav:du,n12:en,n13:r..., LabVIEW  runtime engine 8.6 only supports Vista.
If you wish to use WIndows 7, you need to use LabVIEW 2009.
(4,441 Views)
It's unsupported, but i cant see why it wouldn't work. Win7 is quite similar to Vista in most regards.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,890 Views)
