Running Continuously from the Begining
I am finishing a program and I want it to start running continously from the begining but I cannot find the way to stablish this condition. Does anybody know how to do it?
Really Thanks,
QoergTux
Message 1 of 8
(4,302 Views)
From your VI Front Panel select FILE then VI PROPERTIES.
Use the drop down combo box and slect EXECUTION
Then check the option 'Run When Openend'
Message 2 of 8
(4,294 Views)
Just to clarify, there is no option to start a VI with the "cuntinuous run" button activated. If your VI needs to run contiunously, the main code must be in a while loop (prefereably with a small wait statement).
Now follow Conseil's advice. 😉
Message 3 of 8
(4,286 Views)
It's not advice...
It's counsel... Smiley Happy
As for the original poster, just in case you do this and then you find out that you also close your VI and don't have a way to edit the code, you can get into the code by placing the VI as a subVI inside another VI and then double clicking it.
___________________
Try to take over the world!
Message 4 of 8
(4,280 Views)
Top tip there, well done.
I forgot I knew that one, I saw students on a LabVIEW basics course struggle with trying to get into a VI that had been set up to make it difficult to access. Almost all had to be shown how to get back in.
Message 5 of 8
(4,268 Views)
I'm glad I popped in here today.  That's a good tip that I'll have to keep in mind.  Thanks!
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
Message 6 of 8
(4,264 Views)
... and if you have LabVIEW 8.0, just open it from within the project window and it will not run automatically. 🙂
Message 7 of 8
(4,261 Views)
Another top tip, two in one night.
Fantastic.
Message 8 of 8
(4,256 Views)
