Running DLL compiled in LV 2009 in newer LabView leads to Memory Manager.cpp 547 error
I think the LabVIEW run-time version is a red herring. If it was compiled in LV2009 it will only use the LV2009 run-time. Have you tried reading any of the past discussions about MemoryManager.cpp errors? It sounds like one cause can be the Call Library Function Node, do you use this in your DLL?
Message 11 of 11
(218 Views)
