Running EPOS 2 Maxon Motor via Labview2010
Yes, 32bit LV, 64bit windows 10, 64 bit epos2 driver. Can you tell me how to link the EposCmd.dll? I need to link EposCmd64.dll?
Thank you!
Message 21 of 22
(917 Views)
If you install the drivers from the 3. part driver database from NI.com you will get the dll files into the labview folder. you still need a few dll files from the Epos contol software, at least i did.
I use the 32bit dll since i use the 32bit LV, even thoug its on 64bit system.
you can change the linked dll when you open each of the comands functions and click on the " call liberay function node "
Message 22 of 22
(903 Views)
