Running VI on Myrio using labview 2016
Hey guys so I’m having trouble creating a myrio project. The first thing I try and do is create a new project and then click myrio from the templates. But as you can see from the below picture I don’t get the option of naming or configure the device like the picture below that.
What suppose to happen when I click next after trying to create a “myrio project”
The only way I can create a VI on the myrio is by selecting blank project and from there right clicking on the project tab and then select “new>>devices and targets” as in the picture below.
After that I can select which way to use the myrio as in the below picture.
After that I can finally build a VI on the myrio and access the myrio toolkit see below, but when I try to click on a vi I get this error.
Also when i try and ping the myrio i cant recieve anything i configured wifi connection but nothing and when i enter the ip address of the myrio into the web it doesnt connect. see below.
WIFI configuration
Software Details
Message 1 of 8
(5,401 Views)
One of the error because of different versions of vi and Labview, you can sort it by using : http://digital.ni.com/public.nsf/allkb/C18E6D5FFA8F0D85862568CC0067274F
uday
Message 2 of 8
(5,393 Views)
it still gives same error? I create a vi on the myrio then save as a previous version in this case 15.0.
Message 3 of 8
(5,380 Views)
You have to convert all vis,subvis, controls typedefs everything.
The error specifically showing LED Express VI: where is it ? what version it is?
uday
Message 4 of 8
(5,374 Views)
I only have one vi and so i try doing it as in the picture below.
its the led vi from the myrio pallete see image below. When i try and drop it on the block diagram of laview the error pops up " vi version 16.0 is newer than labview version 16.0b75.
Message 5 of 8
(5,367 Views)
Could you check in NI License manager what versions of following are installed.
  • LabVIEW Development System
  • LabVIEW Real-Time Module
  • LabVIEW myRIO Toolkit
-How did you install Labview and myRIO Toolkit?
-Try installing as bundle to avoid version conflicts: http://www.ni.com/download/ni-myrio-software-2016/6201/en/
uday
Message 6 of 8
(5,350 Views)
this worked thank you, but there is another problem , the safemode on the myrio seems to be broken. It happened when i updated to labview 2016. The software doesnt give me permission to update the safemode. Any idea how i can get the correct safemode verison?
Message 7 of 8
(5,331 Views)
Did you check reset button explanation in manual? Is that what you are checking?
https://www.google.co.in/url?sa=t&source=web&rct=j&url=http://www.ni.com/pdf/manuals/376047a.pdf&ved...
uday
Message 8 of 8
(5,328 Views)
