Running Vi's on the web
I have a desktop application written in labview that I would like to convert
into an application that can run on the internet. I don't have a static IP
address at home, so I would like to publish using my commercial ISP. The
techniques I know of require using the G server, http server, require
labview installed on server, etc. Any suggestions how to proceed? An y
ISP's using G server?
(2,989 Views)
The method for this changed significantly with version 6.1. You will need to use LV's new remote control capability. Your ISP will need to have a copy of the LV runtime engine running on the machine that hosts the application and you will need to buy adequate licenses to allow however many concurrent users you want to support.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,989 Views)
Mike,
Well, how much work involved to convert Labview 6's VI into Web-based VI ? Any tools ?
(2,989 Views)
