Running Vialux ALP4.3 on slave mode
Hello All,
I am trying to project images through Vialux ALP4.3 projector with the aid of external signal. Does anyone have a sample code to run this projector on the slave mode?
(3,345 Views)
What have you done so far on this project. It's unlikely anyone has sample code for that particular projector.  However, we have a lot of the pieces that you might need, so you should be able to put it together. For example, I'm not sure what you are using to read in the external trigger.
Some research shows me that the Vialux ALP4.3 uses a DLL, so this resource might be helpful.
How Do I Call a Dynamic Link Library (DLL) from LabVIEW?
There are a lot of resources available about synchronization. Without more information about what you are doing specifically, I'm not sure which would be best. This might be a good place to start:
Application Design Patterns: Master/Slave
Hope that helps.
Zofia
NI Technical Support Engineer
(3,302 Views)
