Running a Concurrent Server under LabVIEW
I would like to allow multiple UNIX workstations to connect to the same port
on my LabVIEW application. I am currently running version 4.1.
a) Does anyone have concurrent server code that allows multiple clients to
connection to the same port? I did not find this in the example code.
b) Isn't there a Windows 95 limitation of 14 or 15 ports open at a time?
Does NT get around this limitation?
c) Are the examples/function of LabVIEW change in 5.0? 4.1 is inherently
single threaded in operation, 5.0 might better be able to handle parallel
processing by multiple clients connected to the same port.
- Jeff Hartt
Stanford Telecommunications
jeff_hartt@hotmail.com
Message 1 of 1
(3,234 Views)
