Running a Teststand Sequence from LabVIEW.
We have a Test Stand Sequence File, which we, want to execute using a  Custom GUI in LabVIEW. User has to select the sequence file and all other execution must be accomplished in LabVIEW.
Please suggest the ways to implement this.
Message 1 of 9
(5,867 Views)
Creating LabVIEW code to interpret a TestStand sequence would be a very large and task.  I think your best options are 1) Use TestStand, or 2) Manually translate the TS sequence into something else.
Message 2 of 9
(5,832 Views)
I may be missing something, but user interfaces are included with TestStand. Maybe you're looking to not have TestStand installed/running?
Jim
Message 3 of 9
(5,825 Views)
Hi,  PAUL
We're not interpreting , rather wish to execute the Test Stand sequence through LabVIEW UI, instead of Teststand.
Message 4 of 9
(5,794 Views)
Message 5 of 9
(5,790 Views)
It's not clear to me what you are wanting to do.  Is it:
  1. Eliminate TestStand entirely and create LabVIEW code to run a TestStand Sequence?  If so, that's the very large task that I described above,
  2. Create your own custom UI that works with TestStand.  If this is the case, as I recall, the TS documentation tells you how to do that (and gives some examples).
Message 6 of 9
(5,779 Views)
Hi , All ,, I was delay to get my doubt expressed clearly before you. Hope this Picture can explain it better. Please suggest if any one has any idea to start on.
Message 7 of 9
(5,694 Views)
As I said, TS has documentation and examples of how to create your own UI with LabVIEW.
Message 8 of 9
(5,685 Views)
I am also trying to do the same. I have a requirement were the user can select multiple sequences and run it independently from a LV application and generate individual TS reports and each sequence should run one after the other without depending on the result of previous sequence.
Currently I am planning to tweak the example VI available to do the functionality. I will give a update once I finish it.
Message 9 of 9
(5,421 Views)
