Running a VI
Okay, this is probably a dumb one, but -
When you run a .vi file, it is still edit-able. Is there a way to run a vi, or make a "protected" version, so that it can't be edited? Other than with Application Builder, that is...
Thanks -
Dan
(3,086 Views)
Hi Dan, go to File>>VI Properties and select security in the dropdown. You can select "Locked (no password)" and the front panel and block diagram will not be editable. You can also file>>save with options and remove the diagram entirely.
Paul.S
(3,086 Views)
Re: Remove diagram
Make usre you back up first!
Once a diagram is gone, IT IS GONE!
Ben
(3,086 Views)
