Running average after each iteration
Attached is an example of my vi file where I capture data for n iterations and then get a final average of the iterations for only the y-data values.
Message 1 of 9
(7,027 Views)
Attached is an example of my vi file where I capture data for n iterations and then get a final average of the iterations for only the y-data values.  I then plot the final x- vs average y-data.  Is there a way to plot a graph of the average y-data after each iteration instead of just at the end?
hiNi.
Message 2 of 9
(7,026 Views)
Just place a graph in the "For Loop".
You should really connect wires from left to right.
Message 3 of 9
(7,006 Views)
Firstly, is there a way to get the average of the y-data after each iteration?  The way of how I have it set up, the average of the y-data only comes out at the end of the iterations?  Can you assist me in getting the average of the y-data after each iteration?
hiNi
Message 4 of 9
(6,984 Views)
This is another very basic LabVIEW task. You have the orange wire going to your Y data indicator. Browse to the Mathematics>Probability and Statistics palette and select Mean. Wire it up. You could also simply drag a copy of your existing average calculation to inside the loop.
Please see the free LabVIEW training.
Message 5 of 9
(6,972 Views)
OK, I selected the mean function as you recommended, however, I'm having a problem with the task that I originally asked help for.  I was unclear.  I apologize.  However, this is what I would like to get some help to accomplish:
After the first iteration, the data might be:
x-data y-data (iteration #1)
1           .10
2           .30
3           .50...
The graph of the average response after the 1st iteration will have data points:
x-data y-data (Average)
1           .10
2           .30
3           .50...
For the second iteration, the raw data might be:
x-data y-data (iteration #2)
1           .30
2           .10
3           .30...
The graph of the average response after the 2nd iteration will have data points:
x-data y-data (average of iteration #1 and # 2)
1           .20  ((0.1+0.3)/2)
2           .20  ((0.3+0.1)/2)
3           .40  ((0.5+0.3)/2)...
For the third iteration, the raw data might be:
x-data y-data (iteration #3)
1           .40
2           .80
3           .10...
The graph of the average response after the 3rd iteration will have data points:
x-data y-data (average of iteration #1 and # 2 #3)
1           .30  ((0.4+0.2)/2)
2           .50  ((0.8+0.2)/2)
3           .25  ((0.4+0.1)/2)...
hiNi
Message 6 of 9
(6,962 Views)
Hi hiNI,
well, what you describe isn't exactly something called a running average usually...
To get your desired result simply add the new data to theold ones and divide by 2 - it's as simple as described as LabView processes arrays the same way as scalars.
To have a "real" running average simply search this forum, you will find more than one example!
Message Edited by GerdW on 09-13-2008 05:45 PM
Message 7 of 9
(6,935 Views)
All you need to do is sum the Y data array in a shift register and divide by the number of iteration (i+1) for display and further processing.
You code makes no sense, because you generate random x values and also average those. I assume x= constant and just the array index, else nothing would make sense. I also don't know why you generate 2D arrays with stacked FOR loops and then slice out the only data row. Way too much code!
Since X is constant and equally spaced, you can use a waveform graph. Here's a simple example, see if it makes sense. 🙂
It is not a "running average" of e.g. the last x traces, but an average of all N acquisitions as you specified
Message Edited by altenbach on 09-13-2008 10:04 AM
Message 8 of 9
(6,922 Views)
THANK YOU!
That was exactly what I needed!!!
hiNi
Message 9 of 9
(6,873 Views)
