Running *.exe compiled in Labview 8.5.1 on a Windows 7 x64 box
I have executables that were built in Labview 8.5.1 on a Windows XP 32-bit machine and I would like to run them on a Windows 7 x64 machine.  How can I accomplish this task?
Tom
(4,170 Views)
Depending what is in the executable, you should be able to just install it like you did on XP.  If not, I would take the code, update it to LabVIEW 2014 SP1 and rebuild your executables and installers.
(4,165 Views)
I do not have a license for version 2014.  Can I install version 8.5.1 run-time on the Windows 7 x64 machine?
(4,159 Views)
Have you even tried?  I have installed the RTE for 8.5 on Windows 7 machines.  Just be warned that it is not officially supported.
(4,154 Views)
I have not tried out of fear that it may trash my windows 7 installation since it is a work laptop.  Is there a link to the run-time I need to run the 8.5.1 executables?  I do not plan on installing the entire Labview development environment.
Tom
(4,150 Views)
This was the first result from searching LabVIEW 8.5.1 runtime into google.
http://www.ni.com/download/labview-run-time-engine-8.5.1/1019/en/
That being said it might not be all you need.  If for instance the application uses some DAQmx, then you'll need the DAQmx runtime.  Same for VISA, NI-CAN, NI-DMM, etc.
Hopefully you have access to the original machine that it was working on so you can see what other software it had installed to run properly.
(4,141 Views)
