Running executable on re-vamped computer
I have a complex VI supplied by an outside company. Other than a few parameter files and the runtime engine, are any other NI files required to get the application running? The company supplied the computer used for this application and we have had hard drive problems. I need to make certain all files required to run the VI are present.
MR
(2,979 Views)
Does this program/computer "talk" to any instruments? Does it have GPIB or a DAQ card? If the answer is yes to any of these you will need some additional software such as NI-Daq or the GPIB code. You may need to download NI's Measurement and Automation Explorer to configure the other stuff. If you can describe what this system does it would help us determine what you may need.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,977 Views)
Thanks for info, Putnam. Yes, the VI talks to a DAQ (6034E).........
MR
(2,969 Views)
