Running external applications from LabView
Here are some very basic functions that allow you to start, close, minumize, and maximize external applications.
Not much happening on the front panel, take a look at the block diagram.  The string constants are the title of the application as it appears on the title bar when the application is running.
These functions use no other VIs as have been previously seen,  BUT they do use the user32.dll which is normally in the windows system32 directory.
Best Regards
-Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
Message 1 of 1
(2,866 Views)
