Running the VI Analyzer from the Command Line Periodically?
Hello there,
Is it possible to run the VI Analyzer from the command line with a pre-determined configuration? It would be nice to run this as a Windows Scheduled Task on one or more Analyzer configurations.
-Chroma
(3,138 Views)
You could write a VI that uses the VI Analyzer VIs (located in the Programming > VI Analyzer subpalette) that performs a pre-configured analysis.  You can launch LabVIEW from the command line and have it run this VI.  Check out examples\VIAnalyzer to see a few examples of how to use the VI Analyzer VIs.
Good luck,
-D
(3,123 Views)
