I have found something pretty weird while I was trying to do the following:
I have an Array to wich I want to append a new set of data from two sources. To do
this I found two different ways:
1. I can take the array and append every element (from the sources of new data) to
the array.
2. Or, I can create a new array, and append it to the previous one.
Every of those solutions is ilustrated in the enclosed VIs. But the second one
doesn't work correctly. If we run it just once, it will display the correct data,
but if we run it more than once, it will show the cells of the appended data
empty!!!
How come this happens? It seems I'm missing something very basic and i
mportant.
Thank you for your time and help.
JAVIER
Mauricio Vidal
VIDAL & ASTUDILLO Ltda.
http://www.vidalastudillo.com
