Running the same code multiple times with different paramters automatically
Hi guys,
I want to run the same code multiple times with different paramters automatically. Actually, I am doing some sample scans which takes around 2 hours n then I have to be there to change the paramters and run it again. Mostly I do use folowing paramters only
X_Intial, X_Final, X-StepSize
Y_Intial, Y_Final, Y-StepSize
Dushyant
(2,921 Views)
All you have to di is put all of the parameters for each run into a cluster array. Surround your main program with a for loop and wire the cluster array through the for loop. A for loop will autoindex an input array so inside the for loop you just have to unbundle the cluster to get the parameters for each run.
Message Edited by Dennis Knutson on 07-13-2006 07:50 AM
(2,913 Views)
Thanks Dennis
(2,892 Views)
