Running the simulation program in RTX
My simulation program runs fine with windows. Now I am trying to run it with RTX Eval version but the results which I get are not correct. There is no I/O interface in my system. I am giving fixed control inputs and want to view the plots on the screen. I have used Labview 8.0 and simulation module 2.0. Does the simulation module work fine with RTX?
Also, how to view the data on screen from the program running on the RTX? I am checking only the final value presently to verify my results.
thanks and regards,
Rashmi
(2,908 Views)
Hey,
Someone there?????????
Was my question too simple or too difficult?
I haven't got any reply.......
Rashmi
(2,875 Views)
Rashmi,
Sorry this has taken so long to get a response, but I am going to need some more information before I can fully help you.
Just to verify, the results on the Windows system are correct, but they become incorrect when ran on the RTX?
What exactly is incorrect about the results?
Have you tried some LabVIEW examples on the RTX to make sure the output is what was expected?
from the main LV screen>>Find examples >> browse >> toolkits and modules >> control and simulation >> simulation
Chris Van Horn
(2,860 Views)
