Running two Python Coded simultaneously
@cstorey wrote:
TL;DR the python code.  What happens in you just use a batch scripts and call both simultaneously?
Again, maybe some explanation of what you are trying to do, how things are connected, etc.. would help get to a solution.  Do both the scripts use the same bus?  (i.e. are they fighting for resources of GPIB/RS232 at teh same time?)  How are you physically connected to both?  Why not just do both calls in python if you are only using LabVIEW for a GUI?
They use different buses. One is connected by LAN and the other by RS232.  I tried your third suggestion but was instructed to keep separate since they might not have to run together every time.
Message 11 of 12
(1,203 Views)
I would do it this way:
1-Select the Python Node then go to the edit/Create SubVI tab. I create a SubVI for each python node.
2- Open each of this SubVI and in the tab File/VI Properties/Category/Preferred Execution System/ (other 1 and other 2 for each one of the subvi)
Good luck
Message 12 of 12
(1,085 Views)
