Running two different tests on separate monitors
Can I run two different labview executables from one PC on separate monitors
simultaneously? I have a 2 station test facility which I would like to use 1 PC and 2 touchscreen monitors so the 2 operators ccan run different tests on each station  simultaneously.
(2,479 Views)
Yes it works.
You can drag one Application window to the other monitor or use the option at the VI Properties to set the default monitor output of the applications.
But the applications couldn't use the same measurements devices simultaneously.
(2,476 Views)
Accepted by topic author alanled100
As long as you are careful about not using the same resources (files, DAQ devices, etc), you can have as many executables running as you want.
(2,447 Views)
