Runtime 7.1 and Runtime 7.1.1
Hi,all
I wrote VI sequencer that can run different VI's. I was built this sequencer to exe in LabVIEW 7.1.1 and it work as executable and run VI's in run-time engine 7.1.1
Now i have some VI that was wrote in LabVIEW 7.1 and executable can't run it, because VI opened with error:
"VI has an error of type A340. Full development version of LabVIEW is required for fix the errors"
But when i open this VI in LabVIEW 7.1.1 it hasn't errors and only it opened as changed VI (with star) because there is different LV version.
There is some solution for this problem?
(3,125 Views)
I don't know if this is the problem, but you may save the old vi's (and subvi's) with 7.1.1 and try again. Be careful to keep a copy of the 7.1 files.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,113 Views)
Nadav,
Make sure all of your VIs are the same version. Also if you try to run executable built in different versions, make sure you have the corresponding run-time engine.
I did not find any documentation related to your error message. Could you please attach a screenshot of it and also explain how to reproduce the error.
Hope that helps!
Kalin T.
(3,081 Views)
