Runtime Engine installer spawns from unrelated software
Hello all,
When I run a completely unrelated app (Quickbooks timer, in case you're wondering), Windows Installer launches and attempts to install LabVIEW 7.1 runtime engine. Has anyone else encountered this, and why would it occur? Is there an easy solution besides installing the runtime engine?
(3,773 Views)
Hello
This happens with me aswell.
With an application i use to monitor my bandwidth usage.
Its also starting happening when i launch labview.
Its really weird.
Stephen Webb
(3,745 Views)
Hello CT_JIM,
We are probably seeing this behavior because your application (Quickbooks Timer) is querying Windows to confirm that all MSI installers are installed properly. In this case some part of the LabVIEW RTE must not have been installed completely and Windows is trying to correct it.
This can typically be resolved by reinstalling or repairing the RTE to fix the install.
Please let me know if you have any questions.
Matt F
(3,686 Views)
Thanks, Matt -- I'll try that. I guess that confirms my suspicion that I should reinstall Runtime =c)
(3,678 Views)
