06-29-2006 06:02 AM
06-30-2006 08:22 AM
Hello David,
Have you tried running this built EXE on any other machines? If so, do you see the problem on the other machines, or just on the one machine? What is the exact error message you get when running it on that machine? Do you have any drivers installed on the problematic machine? If so, which one(s) and what are the versions? Some drivers might install the 7.1.1 runtime, however, 7.1 applications should be fully compatible with the 7.1.1 runtime, so I too am a bit confused as to what would cause the problem you're seeing.
If you're looking for a quick fix, there's a reasonable chance that going into Add / Remove programs on the problematic machine and asking it to repair the 7.1.x (whichever is listed) runtime would fix the problem, but it's hard to know for sure, the information requested above would help identify this.
Good luck!
07-28-2006 01:07 PM
I am facing the same problem. I built the application on a machine with
LabVIEW 7.1 (Developers Suite August 2005)
Max 4.0.3 (Developer Suite May 2006)
Also installed from May 2006 CDs are
LabVIEW 8.0, LabVIEW Run-Time engine 6.1, LabVIEW Run Time engine 7.0, LabVIEW Run Time engine 7.1, LabVIEW Run Time engine 8.0, NI-DAQmx 8.1.0f1, Traditional NI-DAQ 7.4.1f4.
The exectutable runs fine on the machine that built it. However, if I install and run it on to a different machine with device drivers (MAX from Developer Suite May 2006) installed but without LabVIEW, I receive an error telling me "Executable version (7.1.1) doesn't match resource file (7.1). Check you configuration". If remove the MAX first, then install the executable, I can run the program without the same error. However, I need MAX (device driver) for DAQ.
I did fine a solution. If I install the executable first, and then install MAX, everything works fine., but I do not want to remove/reinstall MAX every time I install an executable.
Where does version 7.1.1 come from? What is the solution?
Thanks.
Ian
07-28-2006
03:11 PM
- last edited on
07-01-2025
03:53 AM
by
Content Cleaner
Just find something from KB
http://digital.ni.com/public.nsf/websearch/6BB601AE18D54C2186256F6C007FD775?OpenDocument
http://digital.ni.com/public.nsf/websearch/680E61A4D02158A186256F7A0073C228?OpenDocument
but how to upgrade to LabVIEW 7.1.1? I have development suite, but only have LabVIEW 7.1 (August 2006) and LabVIEW 8.0 (November 2005).
07-28-2006
05:20 PM
- last edited on
07-01-2025
03:53 AM
by
Content Cleaner
I ran into something like this problem once when I tried to run an application compiled with LabVIEW 7.1 on a computer where the 7.1.1 runtime was installed. The most elegant way around it was to copy the 7.1 version of lvrt.dll to C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1 , renaming the 7.1.1 version that was already there. (Yes, the 7.1.1 and 7.1 Run-Time engines get installed in the same directory!)
If you need the 7.1.1 Run-Time engine, isn't http://digital.ni.com/softlib.nsf/websearch/369618104e25b08e86256f54006a4e2f what you need?
Message Edited by kehander on 07-28-2006 05:23 PM
08-01-2006 09:38 AM
Now I have a new issue. I installed the executable and MAX 4.0.3 (including NI-DAQmx 8.1.0f1 and Traditional NI-DAQ 7.4.1f4) to another computer, but the program can not be loaded properly (error code 21, an external subroutine required for execution could not be found). The vis that have problem are all related to NI-DAQ.
The executable is built using LabVIEW 7.1 (Developer Suite August 2005 version) and runs fine on another machine which at one time has LabVIEW 7.1 installed but later the LabVIEW was removed.
What is the solution? I do need to keep both LabVIEW 7,1 and LabVIEW 8.0 on my master computer.
Ian
08-01-2006 10:05 AM
08-03-2006
08:54 AM
- last edited on
07-01-2025
03:54 AM
by
Content Cleaner
Hi Ian,
Are you using the traditional DAQ VIs in your application? That error you listed means your VI is trying to make calls to a DLL that isn't present on that machine. I would guess that the install didn't run properly. Or all the necessary support for your application didn't install. When you install the driver software you should make sure and restart your PC before trying to run the application.
You're installing all the drivers from the device driver cd aren't you? You could be deselecting something in the installer setup that is necessary for the code to run...
As MAX and NI-DAQ both get installed with NI-DAQmx 8.1 I would suggest downloading the DAQmx driver from the web, burning it onto a CD and using that to build all your deployment machines:
http://digital.ni.com/softlib.nsf/websearch/d31d46fffb745eca862571490053eab8
Did you ever get the problem with LV 7.1.1 solved? If you need the maintenance release it's on this link:
http://digital.ni.com/softlib.nsf/websearch/6C5F342A4AF4EF8986256F5400693C3B?Opendocument
Let me know how you get on with the install of DAQmx 8.1,
Message Edited by SarahB on 08-03-2006 08:55 AM
08-04-2006 08:57 AM
