Runtime for LV community 2025Q3
I created an .exe for my VI, but I have problems to create the installer. It seems that all ok, but when install only install the .exe. I think that is a problem with the NI runtime 2025 Q3.
Please if some body has some idea please infor me.
Thanks to all
MarioChile
(294 Views)
Did you include the runtime in the installer? Please provide significantly more detail.
(261 Views)
Yes, it's appears as installed in the additional runtime alternatives when I preparing the build installer. I'm thinking that the problem is a mistake (my) in indicate the path of the differents elements (vi, .exe). The .exe was created ok.
Thanks for your attention,
(227 Views)
Very thanks for yourd interest. I solve the problem! (not me, but searching in You tube some body named as Stem Code comment without give importance "now we test the installer in an other computer that has not Labview installed". When I did it, the application OK!
It seems that for many persons the fact is obvius.
(179 Views)
