S-parameter to Z
I am working on Data postprocess from an AGILENT Touchstone-file (Freq vs.Real&Imaginary). How do I transpose the S-parameters to Z parameter? In Matlab there exist a simple s2p_function.
(5,719 Views)
I don't know anything about matlab but I know it is supported in Labview 8.0.  You need to have matlab 5.0 or greater installed on the same machine as labview. From here you could call your function inside a Matlab Script Node.
Take a look at the examples shipped with labview. Goto Help -> Find Examples and type matlab into the search tab.
David
(5,711 Views)
Here is a vi to convert S parameters to Z parameters.
Randall Pursley
(5,695 Views)
Cool man!
(5,669 Views)
This VI works only for 2 port networks. what if we have multiple ports? Do you have a VI or any formula in that case?
Thanks.
(3,444 Views)
