SCC Project
Hi, I have couple questions as follow:
- Can I change master directory of SCC after setup?
- Can I use server for Master directory to hold the projects? or it has to be C:\Program Files\National Instruments\LabVIEW 6\project\Source Code Control?
- From Source Code Control Tools I've created Adiministration and Local Configuration, then I try to create a project and it keeps saying "Your hierarchy contains a different list of files compared to the SCC project." even I'd converted the llb file to directory. I've attached the message for your reference.
Thank you
(3,066 Views)
Yes
Yes place the master directory wherever it is convenient.
That is normal. You have an new project and you are asked to add the subVIs in the project. That will popup whenever you add a subVI in the hierarchy.
LabVIEW, C'est LabVIEW
(3,066 Views)
