SCC check-in problem after successful check-out
[1] I get the latest version of my code using "Get Latest Version".
[2] I try to Check-in this same version with no changes. I get the follwing error message
" Error 7 occurred at Invoke Node in Version Control CIN.vi->SCC Enter Change Comments.vi->Builtin SCC Checkin.vi->Builtin SCC Checkin GUI.vi->Check In.vi
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on UNIX."
Any reason why this is occuring? As a check I even tried Checking out the same file after step 1. I get this response
"Error 25556 occurred at Check Out.vi\Builtin S
CC Checkout GUI.vi when attempting an operation on file "D:\CHLA\CHLA-Dev\PktReadAndFormat.vi".
It is already checked out to you"
Hence what is the solution to this problem?
Thanks in advance
(3,095 Views)
Try using the following the procedure to reset the revision history:
1. Go to VI properties, and go to the general tab.
2. Press the button Revision History...
3. Press the reset button and that should clear the
revision history.
This may resolve the problem.
Matthew C
(3,093 Views)
Hi
I have exactly the same problems with some of my vi's in a project. But resetting the revision history doesn't solve the problem. Have you other ideas to go around this problem?
The message is : Error 7 occurred at Invoke Node in Version Control CIN.vi->SCC Enter Change Comments.vi->Builtin SCC Checkin.vi->Builtin SCC Checkin GUI.vi->Check In.vi
Possible reason is File not found. Can you see in the source code what file is missing?
(3,093 Views)
Hi HoSk,
I apologize for the delayed response.
Error 7 will also occur if you try to Check In a VI that is currently open. This may be the problem. You may be getting the File Not Found message for this reason.
I hope this helps!
Matthew C
(3,093 Views)
While using Built-in SCC cannot check-in files after check-out.
Error 7 occurred at Invoke Node in Version Control CIN.vi->SCC Enter Change Comments.vi->Builtin SCC Checkin.vi->SCC menu manager.vi->Builtin SCC.vi->Source Code Control Provider.vi
After clearing revision history (a suggested work-around) get:
Error 6 occurred at Open File in Builtin SCC File Status.vi->SCC Get Master File Status.vi->SCC Get Master File List.vi->Builtin Verify File Status.vi->Builtin SCC Checkin GUI.vi->Check In.vi
I was able to Check-in after closing the vi I was working with (makes sense) but confusion occurred because there is an option under Tool>Source Code Control>Check-in which makes this seem like it should be possible without closing the VI. The VI was saved locally but not closed when I got the errors.
(3,040 Views)
