SCC hangs when I select "Verify System Status"
I completed Administrative Configuration and Local Configuration. I did not yet create a project. Now if I select "Verify System Status" from the Tools menu, a modal window titled "Please Wait" pops up on top of the status dialog. The close window button is disabled so I can't close the dialog and I'm stuck. I must kill LabVIEW and start again.
(2,599 Views)
Hi Ron,
I've done a bit of testing on this end in regards to using the Verify System Status option in LabVIEW's SCC control, and it looks like this is a bug in the LabVIEW. I have tested this feature out with LabVIEW's Built-In SCC, but if you have Perforce or Microsoft's Visual SourceSafe installed, I would be curious to see whether the same behavior occurs. In the meantime, I've filed this as a bug report for R&D to investigate.
In case you're interested in learning more about Source Code Control in LabVIEW, you might be interested in:
NIDZ Tutorial: Software Configuration Management and LabVIEW
Thanks!
Kileen C.
NI
(2,599 Views)
