SCC&perforce
How can I use Perforce as source code controll system in LabVIEW.
I have read in other answers that several use this tool. But I wonder how, because the Perforce SCM doesn't appear in the SCC administration-dialog.
I had tested using Perforce with TestStand, and there it did well.
(2,917 Views)
Perforce was added as a third-party source code control provider in LabVIEW 6.1. It will appear in the configuration dialog if Perforce is registered on your local computer.
(2,917 Views)
