SCC strain gauge vi
Hi
i am using a MSLC G100 load cell to measure downward force. This is connected to a SCC-SG24 module inside a SCC-68 carrier connected to a PCI-6221 DAQ card. I'm using Labview 7.1.1
Does anyone which VI will simply let me read the voltage off it?
i'll be glad of any help
thankyou for your time.
Duncan
(3,003 Views)
an easy way to read the voltage is with the DAQ-Assistant. After you select it, just choose at wich input of your SCC-SG24 you are going to read the voltage. This should work fine.
Joaquin
(2,987 Views)
Thanks for your help.
its working now 🙂
(2,979 Views)
