SCXI-1000 Compatability
Greetings,
I am trying to use the SCXI-1000 with LabVIEW. Since this hardware is discontinued, it is not compatible with newer versions of LabVIEW and NI-MAX. I was wondering what versions of NI-MAX, LabView and DAQmx Base should I use.
I need to make a simple data logging program to save and display data for strain gages. I am currently trying to use LabVIEW 2009, with NI-MAX 5.6, but i cant find a DAQmx Base download previous to 14.0. Therefore, in LabView, I don't get the Data Acquisition palette that I need.
Is there better software to use? Is there somewhere else I can find this version of DAQmx?
Thank you!
(2,985 Views)
Accepted by topic author hecmar.arreola
This article lists the version required for SCXI-1000
https://www.ni.com/en-us/support/documentation/compatibility/08/archived--ni-daqmx-and-ni-daq-driver...
Edit:
As per this article DAQmx 19.0 and earlier supports SCXI devices. https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001Dm21CAC&l=en-US
DAQmx 19.0 readme states that it supports SCXI-1000/DC model - https://www.ni.com/pdf/manuals/374768ab.html#SCXIChassis
Santhosh
Soliton Technologies
(2,978 Views)
Thank you! I will try this out
(2,975 Views)
Can someone tell me why my SCXI boards are not showing up in the configuration on NI MAX?  I have kept Daqmx at 18.5, but NI MAX still does not recognize that I have SCXI modules connected to my system.
Please excuse my posting here.  I couldn't find where to start a new topic.
(2,870 Views)
