SCXI-1161 : Jumper Positions for M-Series controller connection
What should the internal jumpers be set to on a SCXI-1161 (relay card) when plugged into a SCXI-1001 controlled by a M-Series (PCI-6221) DAQ?
The information I have found on the jumper settings is very old, and only mentions E-series ("MIO").
My setup is recognizing the cards but not controlling them.
Thanks!
Richard
(2,504 Views)
Hi Broken Arrow,
You should be able to follow the same configuration as for E Series.  The NI Switches Getting Started Guide and NI Switches Help located at Start»AllPrograms»National Instruments»NI-SWITCH»Documentation discuss this.
David
Digital Multimeters
(2,474 Views)
That's what I thought, but the documentation should be more clear.
Richard
(2,463 Views)
