SCXI 1378
I have 3 SCXI 1378 modules that are attached to the SCXI-1000 module. How can I access them in the Labview VI??
Thanks in advance.
Ashish.
(3,429 Views)
I am using labview 2012.
(3,428 Views)
Have you configured the SCXI Chassis and modules (can you see it listed in MAX)??
Edited: SCXI 1378 is just terminal block (similar to connector block, where you can connect wires/signals) and SCXI 1378 can be used with NI SCXI-1130 Switch.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,415 Views)
Yes.. I am able to see them in MAX..
(3,413 Views)
SCXI 1378 is just a TERMINAL MOUNTING BLOCK (as I mentioned in my previous [edited] post).
So what Multiplexer/Matrix Switch module are using... and have you installed right drivers for this module???
If I'm not wrong, you may also need to install (or confirm if already installed) following drivers.
Switch Driver Installation
(3,408 Views)
