SCXI-1600 support LabVIEW2012SP1
I just upgraded to LV12SP1 and Device Drivers Feb 12. This morning I plugged into a clients SCXI1001 via USB to a SCXI-1600. MAX doesn't see the chassis or the 1600, and Windows Device Manager says my device driver needs to be upgraded. Is SCXI still supported with 2012SP1?
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(3,403 Views)
Search for SCXI-1600.  That particular device is not supported on some versions of Windows.  I do not recall the specifics but know that there is information on the Forums or the Knowledge Base.
Lynn
(3,398 Views)
Okay two laptops running Win7 64-bit are having this issue (cannot see SCXI-1600) but an industrial PC running Win7 32-bit has no problem. So the question is how do I install the device drivers on a 64-bit system so that USB daq devices can be read? Thanx
cell: 516.819.9711
(3,397 Views)
(3,340 Views)
