SDK Function Error While Installing LabVIEW Student 2010
Hello everyone,
I am trying to install LabVIEW Student Edition 2010 on Windows 7 64-bit. I get SDK function error. I searched the knowledgebase questions but it seems the problem is mostly for 2008 versions or older. If anyone knows the solution to this, it would be of great help. Thank you.
(3,042 Views)
Try to start the setup with administrative rights. Looks like a file/dir permission error.
To do that do a right click on setup.exe and choose Run as Administrator.
Hope it helps
Christian
(3,021 Views)
I tried running it as administrator, but still gives the same error.
(2,993 Views)
(2,984 Views)
