SDK error while installing Labview 8.2 on Windows 7
Hello all,
                  I have been trying to install LabVIEW 8.2 version software on Windows 7. I always see an SDK error - 12. I saw an helpful artcle in knowledge base but i am not clear why this is happening?
Could somebody explain indetail whether LV8.2 is compatible with Windows 7?
If it is not compatible then i would like install vista or XP on my new Laptop, to work in LV8.2.
Regards
Visu
(3,943 Views)
Hi Viswa,
Im afraid LabVIEW 8.2 is not compatible with Windows 7. If you wanted to use LabVIEW Windows 7 you would need a later version of LV, such as LabVIEW 2009.
If you need to use LabVIEW 8.2 then installing Vista or XP on your machine would mean you could.
Kind Regards
Michael
NIUK Application Engineer
(3,927 Views)
