SDR
Hello everyone,
I am new to working with SDR device. I'm using SDRplay RSP2pro. I am wondering if I can communicate with this device by Labview and if so how can I do that?
Sam
(5,351 Views)
Hi Sam,
according to its datasheet you get
  • Documented API for new apps development
  • World-class support via www.sdrplay.com
So did you read this API documentation and did you ask that world-class support?
(5,333 Views)
You need to install the drivers, and (according to their site) you get an API. This would be a .dll. This could be a .com, .net or regular dll. This would be described in the documentation. Then you need to make a wrapper around that dll, using activex nodes, .net nodes or call library nodes.
(5,323 Views)
Hi GerdW,
Thanks for your reply I am checking that.
(5,290 Views)
Thanks for your reply it was a good point for start.
(5,288 Views)
Another user did something like that for the RTL-SDR receiver: https://forums.ni.com/t5/Example-Program-Drafts/Using-RTL-SDR-with-Labview-Chapter-1-Labview-on-Wind...
Probably you can derive some good ideas from his example.
(4,936 Views)
