SEARCH ARRAY AND COUNT TRANSITION FROM HIGH TO LOW
I have 4 dig inputs.  I want to count the number of times each individual input transitions from high to low and display the count  I attached the vi as v11.  Thanks for any help.
(2,702 Views)
Accepted by topic author jootbox
Hello Jootbox,
Are you by any chance using a cDAQ 9181 chassis?
If you are it might be a good idea to use the 4 counters internally available on this chassis.
A simple example about counting edges can be found over here:
https://decibel.ni.com/content/docs/DOC-11412
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,699 Views)
Thanks.  That will save me some time.  I have a cDaq-9174.  I'm new to using it and the plug ins.  That's a nice and easy tip you gave me.  Thanks again.
(2,683 Views)
Hello jootbox,
You're welcome.
Kind Regards,
(2,678 Views)
