SEEPOS software problems
hi, i bought a PSD with included software - but am having difficulty with the code provided. I have attached the example below which provides the X and Y positions vs the number of points, how can i change this to the time elapsed and save the data? the 'trim after array' VI provides t_delta ie time between each point so i can use this to provide the timestamps or i will be using a DAQ device so could use the clock on this instead?
Message 1 of 1
(1,210 Views)
