SEH Structured Error Handler Express VI doesn't configure
I stumbled on the SEH and thought "this is exactly what I need!".  I installed it using VIPM package manager, opened the "Central Error Handler Template.vi", got all excited and placed the "Specific Error Handler.vi" on a block diagram.  But imagine my disappointment when it just sat there, NOT configuring like I'd expect an Express VI to do.  I double-clicked the icon, and after about a 15 second wait, a dialog box told me "Unable to view properties".  I don't use Express VI's too much, maybe there is some trick I'm missing.  Does this make sense to anybody?  I'm running LV 2015 Pro on a Windows 7 machine.  Thanks, paul
Message 1 of 8
(4,083 Views)
Did you install the GXML library. It said that it is required.
https://forums.ni.com/t5/Components/Reference-Library-for-Converting-Between-LabVIEW-and-XML-Data/m-...
Tim
GHSP
Message 2 of 8
(4,079 Views)
I am assuming that you found your information here:
https://forums.ni.com/t5/Reference-Design-Content/Structured-Error-Handler-SEH-Library/ta-p/3495302
Tim
GHSP
Message 3 of 8
(4,077 Views)
Exactly, Tim.  It sounds totally wonderful!  But I am super reluctant to go monkeying around with the whole business without having a 110% understanding of it... I wish I knew exactly how the whole Express VI mechanism worked so I could fix it right.  If I don't get a fix, I guess I'm motivated enough to tread carefully into it myself.
Message 4 of 8
(4,059 Views)
Did you install the other files that I referenced in my first post?
Tim
GHSP
Message 5 of 8
(4,053 Views)
Tim - yes, I *think* I did, but I don't have a lot of experience with the JKI VIPM system.  I ran the setup.exe included in "seh_1_0_1.zip".  Then I launched the "ni_seh-2.0.6.9.vip".  It ran and seemed to jump thru the necessary hoops.  *BUT* because of security, the target machine can't be connected to the web, so I have to use DVD's to move stuff back & forth.  Does that answer your question? paul
Message 6 of 8
(4,037 Views)
Accepted by topic author PaulOfElora
I don't think you installed the NI GXML. The version I am seeing is 1.4.2.8 using the JKI VI Package manager. Both of the files that you referenced where for the SEH. The document stated that you need to install the GXML tool kit as well. Perhaps that is the issue.
Tim
GHSP
Message 7 of 8
(4,030 Views)
I reinstalled, and this time I installed the GXML - it all works! Thanks for the tim, Tim!
Message 8 of 8
(3,983 Views)
