SENDING VOLTS VALUES FROM TXT FILE TO POTENTIOMETER
Hi, I am using labview ver 6.1. I need to send 90 voltage values to a potentiometer over 3 secs. At each point in time the pot requires a specific voltage value, say @ t=1.1s v = 4.5v @ t=1.3s v =4.8v.
How can I best ensure that each value is read at it’s allocated time.
Message 1 of 8
(3,226 Views)
Organize the TXT file data like this way:
1.1
4.5
1.3
Then trigger a combination of "read characters from file" and "pick line" each 3 seconeds.
If you still need help tell me.
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
Message 2 of 8
(3,221 Views)
Ok, I got some time !
Here is the code .. See the attachment
Automation Engineer
Egypt - Cairo
Message 3 of 8
(3,218 Views)
UPDATE: I reread your post, It seems that you want all the 90 values to be used in 3 seconeds!
So just change the "Elapsed time" function in my last post to the suitable time (3/90).
Automation Engineer
Egypt - Cairo
Message 4 of 8
(3,214 Views)
Thanks a lot pls see attached the AI will not accept this !! sorry , i am really new to all this . is the timer the correct one?
Message 5 of 8
(3,208 Views)
try this one...
Message 6 of 8
(3,199 Views)
THANKS A GREAT DEAL IT RUNS .
Cheers
Message 7 of 8
(3,193 Views)
Well, Topsy's method is better than mine, but I thought you really want the data to be stored in an external file "to be editted or so!".
Any way, avoid using files if you don't want them.
And about my method, you have to convert the "string" output to be "numeric" before it is used by the AO function.
Good luck
Automation Engineer
Egypt - Cairo
Message 8 of 8
(3,179 Views)
