SERIAL - XY Graph
Greetings. I would like help with the program i am developing:
About the program:
- I am always reading serial to get the ADC values ​​sent by Cortex-M4, being converted to decimal at the end of each reading.
- When receiving values ​​other than zero, I would like to display them on an XY chart, the Y axis being the voltage values.
About the problem:
- The problem is to develop the X-axis. I would like each received value to be tied to an increasing order on that axis.
+ Example:
1nd Value received, being greater than zero: axis x = 1;
2nd value received, being greater than zero: axis x = 2;
3nd.....
I have attached a copy that I have so far.
(2,836 Views)
You need to learn LabVIEW.  Find LabVIEW Tutorials (there are a bunch listed on the first page of this Forum, and NI has a number on their Web Site -- go through all of them, and do all of the Examples).  Where possible, do not use an Express VI.
I'm "suspicious" about your VISA code.  You are reading a pair of bytes at a time, doing some strange processing to them, some strange arithmetic, and then some strange plotting using an unnecessary (and inappropriate) Express VI.
Learn the difference between a Chart and a Graph.
Learn LabVIEW.
Bob Schor
(2,788 Views)
